Hola
He instalado un Dasaita en mi 2008, En principio estoy muy satisfecho con la radio, pero estaria en la gloria si pudiera hacer funcionar una camara trasera, que de momento no soy capaz.
Agradeceria alguna idea o soluccion (quizas en las configuraciones de la radio).
Un saludo.
@Enrique Motilla It will be helpful if you can provide your order number so that we can better assist you. We are wondering if your camera is an OEM one. Please check if you can see a yellow exclaimation logo while you reverse your car or other error notification. Try if you can Enable Factory Camera : Factory setting >Others > Prohibit reverse > Set Enable
If no luck, please go to step 2:
Go to settings > car > factory settings > enter 126 > Canbus and make sure the canbus option is "61", choose the Type on this settings page if needed.
If the above step finished but the problem persists, please kindly confirm the camera cables has been connected properly. You can refer to the following photo.
Please kindly feedback us if the above instruction can help you get the problem resolved. If not, please show us a photo of the wirings on the back side and send us the error notification, so that we can forward to our manufacturer for further instruction.
@Enrique Motilla We noticed that we haven't received a response from you in quite some time, and we wanted to check if the issue has been resolved. If it hasn't, kindly provide us with a list of all the current issues you're facing with the unit so that we can offer further assistance.
@Support Dasaita Hola, buenos dias
Lamento comunicarles que no se me ha resuelto el problema aun cuando he realizado las comprobaciones que me indicaban. He realizado la indicacion, cambus esta en 61. La cámara funciona pero solo desde la app de camara delantera cambiando a la trasera, pero sigue sin conectarse al poner la marcha atrás.
@Enrique Motilla We are wondering if you have already gone to Factory setting > Other > Prohibit Reverse > Set "Enable" , please send us a screenshot on this page.
If the problem persists after the above settings, please navigate to: Factory settings > enter 126 > Canbus and send us a screenshot to see your chosen canbus and the type. Please let us know your car year and more detail car model.
If you have done the above instruction but still no luck, please send us a photo of the wirings on the back side so that we can check if the wirings is correct or not.
