I have a 2017 Toyota Highland and have recently purchased the Dasaita Vivid 11. I followed the install directions per the instructions/youtube. My car has USB ports that are under the dash. If I plug my iphone in it will "charge" my phone, however my Vivid 11 will not link to the phone via USB only BT. Any ideas what might be the issue? I checked for software updates, updated, still not working.
@M D Hi there, we have 2 USB cable, one single USB and the other DUAL USB cable, you can use the cable named Phone link on the Dual on to charge your phone. Note that you need an original or data transfer-compatible USB cable to connect your phone.
@M D there is a special cable adaptor to retain the stock usb ports by connecting them to the dasaita usb.
Check on the supplied wires with the unit.
