I recently installed Vivid11 in my 2013 EX M6 USA. From technical support I needed to choose correct cable bundle and moved TFT box to get right side mirror working. Everything seems to work, except the phone call buttons on steering wheel. The round button for volume, mode/select, and CH+/Ch- work, and I assume that is from what Dasaita calls the bluetooth wire, or pink wire. However, I believe the 3 lower phone buttons are not connected via pink wire, but perhaps a purple or light blue wire after I found schematics of Honda. See attached partial schematic. To repeat, Audo Remote Switch buttons on steering wheel work, but Voice Contro Switch buttons DO NOT work.
I believe there is a fault in cables or some other connection nedds to be made.
How to fix this ?
