I have a PX6 Android 10 headunit. I have just updated it to firmware version 20231102 (the one that combines Vivid and Scout) and also updated the launcher to version 7.1.3860.
Now I'm trying to install the Scout Maps APK to have the map in the left side of the home screen (instead of the clock and velocimeter widgets), but when I try to install the APK (ScoutNav-production-arm64-v8a-release-2.2.21.0.6-signed.apk), I get an error saying "The application was not installed". Any idea what the problem could be? Here is a screenshot of my unit versions just in case it helps.
Thank you in advance.
@Luis Sánchez no te saldra mapa pongas lo que pongas, solo.salen para Estados Unidos, México y alguno más para Europa nada.
@Luis Sánchez We would like to tell you that the Scout Map is for United States. Here is the APK of it.
https://scout-ivi.s3.amazonaws.com/map/USAM/23Q1/TelenavMapData.tar.gz
@Support Dasaita Thank you. So I guess it doesn't work in Spain right? any estimation when it could be available for Europe/Spain?
@Luis Sánchez We would like to tell you that the left widget customization will be improved in about Feb. Once the new firmware has released we will put the link to the forum. You could pay attention to our forum as well.
@Support Dasaita any update on the new firmware release to support Scout maps APK?
Realmente tienes una solucion, seria actualizar a Laucher 3 marcando la casilla pequeña.
Una vez Actualizado seria meter una apk de Vivid la cual si trae el Google maps en el lado izquierdo y lo tendrás a tu gusto.
Espero a verte podido solucionar lo que querias.
Gracias @Juan Perez, probaré esa solución a ver que tal 👍
Te dejo mi correo por si necesitas que te echen una mano.
mirlacos@gmail.com
@Luis Sánchez Sorry that we do not have android 10 that could customize the left widget.
Your topic is very good, please share more new things. I'm interested in minecraft apk they are very nice and attractive, you can visit
PX6 headunit upgrade left Ninja Arashi puzzled! New firmware, launcher updated, but Scout Maps APK refuses to install. Any tips to conquer this roadblock?
