Dasaita 10.2 Android 11 Car Stereo for Toyota Camry 2012-14
When I first installed it, I'd hear a normal ringtone coming through my car speakers when I received a call to my Bluetooth-paired phone.
I've changed phones a couple of times since then. Currently, I have a Pixel 6a. When I get a call, the Dasaita plays a super-loud - I mean, volume at 11 - buzzing noise instead of a ringtone. Everything else about the call is normal.
I recently did a factory reset of the Dasaita to clear some other issues, but I'm still getting an ear-splitting buzz instead of a ringtone.
Any ideas on what to do?
@Ed InSac We would like to tell you that the volume is controlled not only by our head unit but your phone as well. Please make sure that volume on your phone is suitable and then go to Settings > Car > Factory settings > enter 126 > Voice and adjust the sound of BT to be an average level. Your cooperation will be appreciated.
The volume level has been adjusted and it's fine. The tone for an incoming call is still a buzz, like the buzzing you can hear on AM radio, rather than a ringtone. Any further advice to solve this would be appreciated.
@Ed InSac Please let us know your order number and the following information so that we could better locate and give you more appropriate instruction.
1. Go to Settings > About machine and send us screenshot of the current Build Number.
2. Go to Settings > About machine and send us screenshot of the current MCU version
Try downloading new ringtones at the website: https://dzwonkipl.com/
I also had the problem of incorrect sound when receiving calls and solved the problem by downloading a new ringtone and resetting. You can try the same by going to songringtone.net to download a new ringtone and adjust the sound settings. Hope this helps!
Try these steps:
- Update the Dasaita firmware.
- Check the audio settings on the Pixel 6a and Dasaita.
- Delete the Bluetooth connection and pair again.
- Check the ringtone settings on the Dasaita.
- Adjust the volume or check for electrical interference.
If that doesn't work, visit tonuri de apel to download and reinstall the ringtone
@james selenla
Hi James,
If the issue still exist?
Could you please send a video of showing this issue?So that we could better confirm.
Try turning Bluetooth off and on, forgetting the Dasaita device on your phone, adjusting the call volume, and checking for software updates. If the ringtone problem is still not resolved, you can visit https://nhacchuongviet.com/ to download and reinstall the ringtone.
Try going to bruitages gratuits to find and change the simple ringtone on Pixel 6a, test the sound and update the firmware for Dasaita.
Free ringtones and sound effects: Soundeffekte.net.
