Backup Camera audio cut
  • Hi, thanks in advance for any and all support here. Is there anyway on a G12 system to change the audio or backup camera settings so that when the backup camera is engaged, the audio (android auto, bluetooth, radio) does not stop playing?
    Thanks again!
  • @Mike McG Hi customer, in this case, you could just factory reset the system. Here is the path.
    Go to Settings > System and choose factory reset the system.
    If still no luck, please kindly go to Settings > About Machine and send us the current Build Number and MCU version. We may guide you through an update of the firmware.
