Bonjour,
J'ai un Dasaita pour NISSAN X-TRAIL ANDROID 10, tablette PX6.
Version MCU : MTCE_HA_V3.78_1
Problème : J'ai toujours une mise à jour automatique de Android système WEBVIEW.
Ensuite les applications google refusent de demarrer (WAZE, CHROME, etc..)
Je suis toujours obligé de désinstaller les mises à jour de WEBVIEW.
Avez-vous une solution pour résoudre ce problème ? Peut-être une mise à jour du MCU ?
Merci pour votre aide.
Yannick.
Same car, same issue - I'm not sure about the software versions, but everything is up to date, so probably they are the same ...
This issue is very very annoying !!!!
@YANNICK OULD SLIMANE @Georgi Pekov Please go to Settings > About Machine and send us the current Build Number and MCU. We are afraid that some apps version is too new that the head unit is incompatible.
Please go to Settings > Network & internet > turn off the "Private DNS". This interferes with logging into Spotify and getting applications like Waze to connect to the internet. Hope this helps.
The Private DNS setting does not change anything. The only solution I got at the moment is to uninstall the updates for Android System WebView, but it updates the very next day ( no matter that I forbid the application updates in play store )
update the system and the bug is fixed, it has been fixed for a long time but you don't see it updated, your system is from 2022.@Georgi Pekov
Bonjour,
Le DNS privé ne change rien non plus !
Voici les informations demandées .
@Georgi Pekov Please kindly update the firmware to MAX10(20230302) to check if the issue could be resolved or not. https://www.dropbox.com/s/5w50x3fqkvhiv3f/ha3_rk3399_10.0_ota%2820230302%2B%E8%93%9D%E7%89%99MCU%29.zip?dl=0
@YANNICK OULD SLIMANE Please kindly update the firmware to MAX10(20230302) to check if the issue could be resolved or not.
Ok, I will try to update it today ( I already did it 2 years ago when I talked with your Aliexpress support - it was connected with not working wifi ( did not fix the issue with the wifi, till this day I have to restart the system every day so I can have wifi) ). Just one question, even a few days ago I had a notification for a system update and I did it - how is that possible that my firmware is from 2022 ?! Should I update the firmware manually every time?
@Georgi Pekov Maybe the topic could tell the difference of OTA and firmware.
https://www.dasaita.com/community/forum/topic/122055/a-quick-guide-of-firmware-mcu-ota-updates
Bonjour à Tous,
Merci beaucoup pour vos réponses.
Je n'ai encore jamais fait de mise à jour, avez-vous une procedure à suivre ou des conseil pour faire la mise à jour correctement?
Merci d'avance.
Yannick.
I updated the firmware ( the kernel version changed ) and for now, I have no issues with the Android System WebView.
Bonjour,
J'ai mis à jour le firmware et effectivement la version du noyeau a changé.
J'ai mis aussi à jour GOOGLE CHROME qui faisait planter Waze et là je n'ai plus de problème pour le moment.
J'attend la mise à jour automatique de WEBVIEW car je n'ai pas la main, pour confirmer le bon fonctionnement.
Merci
@YANNICK OULD SLIMANE We are wondering if the WebView you mean is the Chrome that you pre-install or you could show us which apps that you mean.
Bonjour,
Mon application WAZE plantait, dès que j'avais une mise à jour de GOOGLE CHROME ou ANDROID SYSTEME WEBVIEW. Depuis que j'ai mis à jour le firmware avec la version que vous m'avez fourni, j'ai essayé la mise à jour de GOOGLE CHROME et tout vas bien. Par contre VEBVIEW, il est mis à jour automatiquement par GOOGLE donc je n'ai pas encore testé. Mais je suis confiant car vous avez fait du bon travail avec cette version du firmware.
Je reviendrai vous dire si ca marche bienaprès la mise à jour de WEBVIEW.
@Support Dasaita hi i have the
same problem with my dasaita.
Can you give me the update please.
@Tuniskimo Please update the to the latest MAX10.
HA3_rk3399_10.0_ota(20230803)
@Support Dasaita sory but i have a problem
The package IS not good my device IS rk3368
It's a PX5
Have you got an update
