@Randy T We check our system, the head unit that you sent you do not support zlink, you could also check the listing of you order, we have not mentioned anything about this feature.
@Support Dasaita OK, I understand. So, even though it has Zlink installed, there is no way to make it work? Is it just because it cannot be activated/licensed or does it just not work at the hardware level?
@Randy T Yes, Zlink is not supported by the W11 version's mother board so although you install the software it will not activate the zlink.
@Support Dasaita OK, thank you.
G12(20240606):
@Support Dasaita can i up via ota now or have to download the zip file ?
@Khang Viet Hi you could up via ota now!
@Support Dasaita Checked today Jun 9, 2024. New version is not available via OTA.
"Edit" Update installed. All ok. Thanks
@Support Dasaita esto se debería poner en la sección de firmware ordenado con las diferentes radios que tenéis en venta para mejor visionado.
Gracias
@Support Dasaita where do I find the settings for the screensaver? Specifically where do I disable it?
Hola buenas tardes. Cual es el ultimo MCU para dasaita G12 Nissan Qashqai J11? Saludos
@Gavin Swanson imagino en ajustes de pantalla. Saludos
@Gavin Swanson Please go to Settings > Display > Audio timer to set the screensaver time or disable it.
@Alberto Soria Trigo Hello, the latest firmware is 20240606, and the MCU is 4.13.
@Support Dasaita perfecto, y donde puedo descargar el MCU solamente.
Tengo la ultima versión del software en la G12 Nissan Qashqai J11 pero el MCU no se actualizo.
@Alberto Soria Trigo Here is the 4.13a MCU: https://www.dropbox.com/scl/fi/3eo7wplzcyw077zcsqaht/hmcu.img?rlkey=xj47j3cxpzjsi3grmqf65ouen&dl=0
@Support Dasaita gracias. Estos detalles los deberíais poner en el anclado de la zona de firmware.
El que no sabe, como yo va a preguntar de seguido todos loas días.
Saludos
@Alberto Soria Trigo Thank you for your suggestion. The firmware is just for G12, we are afraid that someone will update for other series which may cause defection or risk for their stereo.
I have a PX6 Android 10 and the brightness is very low ( it starts normal sometimes and then reverts to low brightness) . Is there an MCU update and android update ?
Thank you !
