Will this procedure help to connect the OBDLink MX+ adapter to my G13? The Bluetooth module FSC-BW124 is installed. The device sees it but cannot connect. The HA5225 CB008 device for Nissan qashqai.
@Ronny K_Vcore
For your information, G13 doesn't support OBD Link MX+ adapter.
If needed, we suggest that you can connect this OBD:
https://www.dasaita.com/products/dasaita-obd2-car-automotive-diagnostic-scanner-save-share-reports-torque-app-plug-into-car-directly-car-diagnostic-scanner-tool?_pos=1&_sid=b6e3d4d0c&_ss=r
Thanks for the offer, but in this case I decided to use USB ELM327, it connected perfectly and works faster than Bluetooth OBDLink MX+. Advice to those who decided to connect the same way - in the adapter, the USB-UART converter should be on ft232, the drivers for it are in the system.
@Ronny K_Vcore
You are welcome :)
We appreciate for your advice as well.
For anyone who cannot find "factory settings", its under "Car" -took me an hr!
I purchased my G12 unit in Dec 2024 and everything was up to date for System (QCM6125_202409303-1414) and MCU(V4.14.1). I downloaded the BT file from the given link (BT1031p_update.bin) and saved to a USB drive (not in a folder), connected to the headunit USB cable that runs with the phone USB cable. Once I entered "hctbtup" it uploaded the bin file immediatly and I was then able to connect my ELM through the head unit, then torque automatically had the Elm BT module connected when I oppened it.
@James Thompson Hi James,
Do you want to system update or want to install the OBD apk?
Hi will this only work with the apk provided or can I install Torque from the Play Store?
@raj s
For your information, it works with the apk provided only.
@Ronny K_Vcore Awesome. Can you elaborate? Can you recommend an adapter? Does something on Amazon look good? Which five pins are you connecting to on the back of the head unit?
@Matt Stensland I have one single and one dual USB. I connected to all three, it works in all three. I have a qashqai and it is important for me to use the cvtz50 program to see the parameters of the variator. Everything worked in all three USB ports. I placed it inside next to the OBD connector. I had to make a cable with a small connector so that it could be connected and closed with a lid. I'm from Russia and we have Amazon and Ebay under sanctions. We buy everything on Aliexpress. Russia and China are forever friends!!!!!!
Thanks so much for the info, Ronny!
