How to change the side LED buttons
  • Navigate to Settings > Car > Driving settings to customize the color of LED light.
    Here is the video instruction.🧐
  • My G12 doesn't have this. Did an update get rid of this feature?
  • @Chris Justice This feature is for head unit which has LED touch key, if your head unit is 12.3 inch or the HA2220, you may have no access to change it.
  • It's a 10.2 android G12 model.
  • @Chris Justice Could you please send us a photo of the head unit that you own? We will check accordingly, or you could go to Settings > Car > Driving settings, send us a screenshot of the settings options. Your cooperation will be appreciated.
  • I actually went into factory settings. It's shows that it can be changed to RGB led. I changed it and got the "LED setting menu, can pick any color but it only stays blue. So I guess I only have blue leds. Very odd that you show how to do this when some of the units will not. I have the Android G12 10.2 for the Toyota tundra.
  • @Chris Justice No, you should go to Car > LED settings to change the LED color.
