Using a different launcher
  • Hello, I want to use "Car Web Guru" launcher but I can't use the Android Auto shortcut that appears with the Vivid launcher in te apps list. I can only choose ZLink, the separate icons for Car Play and Android Auto do not show. The problem is that when ZLink starts up it runs Car Play directly, I can't choose to use Android Auto by default.
    I am connecting by cable, therefore it does not affect the Bluetooth connection.
    Please, how can i configure ZLink to use Android Auto by default?
    I have Dasaita PX6 Vivid 11 for Toyota CHR.
  • @Jose Gonzalez Pareja Please go to Factory Settings > enter 126 > Apps > turn off and then turn on the zlink to check if your new launcher could see those separate icons.
  • Hi, how do I use the Vivid launcher on the G13 head unit? The launcher is asking for storage access but that is not a permission that is available in the settings. I've enabled all permissions for the launcher but it seems to be missing that one.
  • @raj s
    For your information, different versions(G13/Vivid13) have different launcher.
    If you prefer to the Vivid launcher, it needs you to reflash to Vivid13 from G13.
    However, we don't recommend to do this operation cause it involves the potential risks.
