Front cam won't work
  • Order number113-5362167-5866643
    2019 tundra CrewMax TRD pro
    I recently installed a front camera and have it hooked up to the correct port in the back of the unit which is f cam but cannot get it to work with the Fcam app.  It works if I switch it to the rear camera port so I know the camera is working.  Is there a setting or something I am missing
  • @Al Simmons Have you asked for a refund and not return the item to our warehouse yet? We checked our systems, we have already issued full refund to your order.
  • Probably wrongo order number.  I bought same one.
  • Right now it is plugged into the f cam port on back of the unit the reverse camera is plugged into the camera port so do I need to connect the front camera to something else
  • @Al Simmons We have a front camera wiring instruction, you could refer to it.
