2013-2017 Accord EX-L Issues
  • @Support Dasaita my sub does work, but it is super quiet. Unfortunately I never paid close attention to what the OEM radio did so I am not sure if it's just a weak sub in general or if the signal the Dasaita output is giving it is truly lower.
  • @Support Dasaita,
    If I disconnect my speakers and turn the volume up, my sub will start to work. It is very low volume. I'd be happy to try the modified amplifier.
    I installed the MCU, I'm not sure why nothing worked last time, but installing this one worked. I have the same issue as @Erik Anderson, the lane change button turns off the camera, but does not turn it on. I don't really care about the camera turning on at all with the signal, but the button is important.
    The .apk still doesn't work (says it's invalid) for the clock issue. (00:15 instead of 12:15). The other issue with the time is that it will show 03:15 instead of 3:15 on the clock screen with the stars. I can send a picture if needed. @Erik Anderson - What are the changes with the APK link that you posted?
  • @Jonathan Blackwell
    We are sorry to let you know the all the time display format could not be change this period as our engineer is hard to make it compatible, we are still tackling this issue.
    As to the APK, it's the same as the one that we sent you.
    Regarding to the right turn issue, we have reflected to the engineer and once getting new software, we will let you know.
    For the modified amplifier, we will modify one for you, we are wondering if you could write an email regarding to this issue, we would like to confirm the shipping information with you. email: support@dasaita.com
    I received the following:
    Let me know how to install it.
    We have arranged the personnel to follow up on your case via email.
    Please pay attention to your mail box and discuss the details further with our personnel.
    ✉️Email: support@dasaita.com
  • @Support Dasaita is there any update re: the regression with the right view (lane watch) button when the turn signal is not on? If you need any more details please let me know. My spouse is a bit annoyed by the situation. 😅
  • @Jonathan Blackwell @Erik Anderson We are sorry that the engineer is still studying the issue, could you please update the MCU back to the previous version MCU 4.12b.
    As to the time display on the iMid Screen and the main screen, we have a Canbus APK, could you please kindly update check if they could display in the same format? Go to APK installer to install it.
    https://www.dropbox.com/scl/fi/j8z6rf1ypd7biumic7ksj/HCTCanBus.apk?rlkey=9eftm8923pmpi2o0hxdyrj7uo&dl=0
  • @Support Dasaita I get a "App not installed as package appears to be invalid" error when attempting to install that APK.
  • @Erik Anderson Hi there, we are wondering if you have updated the firmware to Vivid 13, if so, please kindly scroll back the G12 version and then install the Canbus APK.
  • @Jonathan Blackwell Hi, we have not received your email for a few days, we are wondering if your issue has been resolved or not. Did you successfully install the APK? Can the bass work well after you install the amplifier?
  • @Support Dasaita,
    Sorry. I have been traveling for work and didn't have access to my car.
    I installed the Subwoofer adapter. That worked. The APK from the link above, again, says that the package is invalid.
  • @Support Dasaita,
  • @Jonathan Blackwell Hi there, we are wondering if you have updated the firmware to Vivid 13, if so, please kindly scroll back the G12 version and then install the Canbus APK.
  • @Support Dasaita I had updated to Vivid 13 because of an updater you'd asked me to install earlier.
    I just installed G12 again. Perhaps not surprisingly (due to downgrading the OS), it entered a boot loop but luckily the recovery partition kicked in and allowed me to reset everything. That allowed it to boot successfully.
    After that, I was able to install the CAN bus APK.
    The good news is that it can now format time correctly as 12:xx instead of 00:xx.
    The bad news is there is a much worse regression, which is the hour display is typically wrong. I took a video demonstrating the issue:
    As you can see, the time is set to 11:36am and the headunit itself shows that. After ~5 seconds, the iMID screen shows the wrong hour time with the correct minutes (02:36). If I leave it alone, it will after some time briefly switch back to displaying the correct time (e.g. 11:36) but a short time later go back to showing the wrong time again.
  • @Support Dasaita are these two issues (the clock issue and the lane watch button behavior) still being worked on? Please let me know if/when you have something new that you'd like me to test.
  • @Erik Anderson @Jonathan Blackwell
    Hope the message could finds you well!☺️
    Please kindly assist in printing the log of the canbus about the right turn issue.
    Here is the instruction.
    1.Please go to Settings > Car > Factory Settings > enter "logcan".
    2.Then you will enter the following page, change the option to "70".
    3. You could turn right and then press the right turn buttons. The operation log will be show on this page. You could repeat a few times.
    4. Please shot a video of the whole process and save the log and exit.
    5. Go to filebrowser and copy the canbus log file along with the video to us.
    You could send them to our support email: support@dasaita.com or just send them here.
    Thank you for your cooperation in advance.
  • @Support Dasaita really sorry for the delay! I had a lot of travel over the past month where I didn't have access to the vehicle. I should be much more responsive moving forward.
    Here's a video recording:
    The timestamps to note are:
    0:03: a quick tap of the "lane watch button" at the end of the turn signal stalk
    0:07 to 0:11: a long press of the "lane watch button"
    0:14: turn on the right turn signal
    0:25: a quick tap of the "lane watch button" while the right turn signal is still on
    0:30: turn off the right turn signal
    0:34: turn on the left turn signal
    0:44: a quick tap of the "lane watch button" while the left turn signal is still on
    0:48: turn off the left turn signal
    0:51 to 0:59: a long press of the "lane watch button"
    And here is the associated CAN bus logging:
    08:23:41:095:  2E 70 02 00 40 4D
    08:23:41:214:  2E 70 02 00 00 8D
    08:23:45:206:  2E 70 02 00 40 4D
    08:23:49:479:  2E 70 02 00 00 8D
    08:23:52:366:  2E 70 02 00 80 0D
    08:23:53:294:  2E 70 02 00 80 0D
    08:23:54:324:  2E 70 02 00 80 0D
    08:23:55:324:  2E 70 02 00 80 0D
    08:23:56:325:  2E 70 02 00 80 0D
    08:23:57:325:  2E 70 02 00 80 0D
    08:23:58:326:  2E 70 02 00 80 0D
    08:23:59:335:  2E 70 02 00 80 0D
    08:24:00:334:  2E 70 02 00 80 0D
    08:24:01:345:  2E 70 02 00 80 0D
    08:24:02:349:  2E 70 02 00 80 0D
    08:24:03:286:  2E 70 02 00 80 0D
    08:24:03:474:  2E 70 02 00 C0 CD
    08:24:03:614:  2E 70 02 00 80 0D
    08:24:04:297:  2E 70 02 00 80 0D
    08:24:05:325:  2E 70 02 00 80 0D
    08:24:06:326:  2E 70 02 00 80 0D
    08:24:07:335:  2E 70 02 00 80 0D
    08:24:08:346:  2E 70 02 00 80 0D
    08:24:09:356:  2E 70 02 00 80 0D
    08:24:09:555:  2E 70 02 00 00 8D
    08:24:09:656:  2E 70 02 00 00 8D
    08:24:09:756:  2E 70 02 00 00 8D
    08:24:09:854:  2E 70 02 00 00 8D
    08:24:11:777:  2E 70 02 00 08 85
    08:24:12:696:  2E 70 02 00 08 85
    08:24:13:704:  2E 70 02 00 08 85
    08:24:14:705:  2E 70 02 00 08 85
    08:24:15:707:  2E 70 02 00 08 85
    08:24:16:706:  2E 70 02 00 08 85
    08:24:17:726:  2E 70 02 00 08 85
    08:24:18:726:  2E 70 02 00 08 85
    08:24:19:726:  2E 70 02 00 08 85
    08:24:20:726:  2E 70 02 00 08 85
    08:24:21:735:  2E 70 02 00 08 85
    08:24:21:742:  2E 70 02 00 48 45
    08:24:22:057:  2E 70 02 00 08 85
    08:24:22:753:  2E 70 02 00 08 85
    08:24:23:706:  2E 70 02 00 08 85
    08:24:24:736:  2E 70 02 00 08 85
    08:24:25:744:  2E 70 02 00 08 85
    08:24:26:748:  2E 70 02 00 08 85
    08:24:27:580:  2E 70 02 00 00 8D
    08:24:27:670:  2E 70 02 00 00 8D
    08:24:27:678:  2E 70 02 00 00 8D
    08:24:27:876:  2E 70 02 00 00 8D
    08:24:28:685:  2E 70 02 00 40 4D
    08:24:36:684:  2E 70 02 00 00 8D
  • Also, to note what should happen with the camera at those timestamps:
    > The lane watch camera should be on (turn signal off, but camera state was toggled).
    > The lane watch camera state should toggle and turn off as soon as the button is pressed (0:07).
    > The lane watch camera should be on because it should always turn on when the right turn signal is first activated..
    > The lane watch camera state should toggle and be off.
    > The lane watch camera should remain off.
    > The lane watch camera should remain off (the left turn signal shouldn't interact with it).
    > The lane watch camera should toggle and turn on.
    > The lane watch camera should remain on. I don't recall what the OEM system does, but the left turn signal should ideally not interact with it.
    > The lane watch camera should toggle and be off after the start of the press (0:51).
  • @Erik Anderson
    Hello, Erik.
    Thank you so much for sharing the related information.
    We have forwarded it to our technician and arranged the personnel to follow up on your order via email.
    Please pay attention to your mail box and discuss the details further with our personnel in the email.
    Hope you have a nice day!
  • Thanks for working through the issues via email. The updates you provided appear to have fixed the lane watch button and clock display issues.
