2015 Door Lock Beep Stopped Working After Latest Update
  • Hello. I just updated my heading in my 2015 Tundra and now the door lock beep does not work. Before the upgrade the truck would beep when I locked the doors with the remote and beep twice when unlocked it. Now, there is no sound. Is this a setting that is controlled in the head unit? If so, where can I find it?
  • @Kto Kto Please let us know your order number so that we could locate more order detail and give you more appropriate instruction.
    Besides, go to Control Settings on the home page and check if there is a setting for the door lock beep. Your cooperation and prompt reply will be appreciated.
  • Mine did the same thing on a 2014 tundra. All setting they said to try didn't work. Had to buy a OBD2 Bluetooth connector and use the app Carista to turn it back on. You have to pay for a months subscription. $10. Sucks but that's the only thing I could do to fix it.
  • @Chris Justice Do you mean that all the control Settings could not work? And then you purchase a OBD2 and the control settings could work now.
  • @Support Dasaita I have looked through all of the settings and am not seeing door lock beep.
    This is quite unfortunate.
  • @Support Dasaita   No control settings work. There just is no setting to turn the lock and unlock beep on or off.
  • @Chris Justice Please send us your order number so that we could record and send your model to the engineer to check the issue.
  • @Kto Kto Please send us your order number so that we could record and send your model to the engineer to check the issue. Normally, we just retain most of the OEM features not all of them, hope you could understand.
  • Just installed my radio and the beeping stopped to when you lock and unlock. I did used the carista obd2 connector to turn that feature back on. But as soon as you touch the car settings features. The beeping stops again.
  • @Benjamin Atienza
    In order to help you better, could you please provide the following information?
    Order number.
    The specific car Model & Year.
    The front&back side clear photo of OEM radio.
    Please confirm whether your original head unit has the related settings about lock/unlock tone.
  • 114-8354208-2175435
    2015 Toyota tundra SR5
    my original head unit did not have the option to turn off/on the beep.
    but it made sounds before I installed the Dasaita radio.
  • @Benjamin Atienza
    Hello, friend.
    Please refer to video:
    https://www.youtube.com/watch?v=yVdQd9UjAzA
    If possible, please try to do as follows:
    Insert the car key, turn it to "On" position firstly.
    After about 10 seconds, press "Unlock"button 2 times on the hand held remote.
    Then turn off the car, and go outside to check if it works for "beep" when you press "Lock"/"Unlock"buttons.
  • Yeah.... that doesn't work with my truck
  • @Benjamin Atienza
    We have reflected it to our technician.
    We also arranged the personnel to follow up on your order.
    Any news, our personnel will connect you.
    Please pay attention to your Amazon message/mail box.
  • @Benjamin Atienza
    Hi Benjamin,shall we get in touch with our Dasaita support team emails:team@dasaita.com.
    So that we could send a update file to get the beep sound issue resolved.
