After update to scout I've surprised of the quich start. It works pretty fine.
However I've two maior issues. In the standard dashboard there is clock speedometer on the left and music player on the right. How can I change the left side e.g. navigation.
Secondly after update to scout I see in the small android widget of the audio sources three chinese audio apps. How can I delete them.
Thx for support.
@Adolf Klenk Please let us know your current Build Number and MCU version so that we could better confirm if your version supports the customization.
MCU is:
MTCH_HA_V3.89a_1
Aug 17 2022 13:27:20
Build no is:
rk3399-userdebug 11 RQ3A.210705.001 eng.hct2.20220803.111156 release-keys
Kernel Version
4.19.193
#470 Wed Jul 13 19:46:44 CST 2022
Hope this info will work.
Thx for support
kr
Adi
I'm having the same issue, I am based in the UK. Mine updated to a new version yesterday and a map was on the left for about 5mins when it weas updating. Now it has disappeared again. I would definitely like the map function back as I had it when we first bought the unit
@Adolf Klenk Please update the latest vivid firmware.
@Jason Man We are wondering if you could turn on the map and then go to the home page to check if the map is on the left widget.
Hiya, just tried using Google Maps, still no map on the left widget.
Is there something I need to do to set that up first?
@Jason Man We are wondering if you could record a video to show us the whole process you use the map, we will check if the procedure is correct or not.
@Support Dasaita tried to download your file onto my macbook. However it failed because my internet connection goes via mobile hot spot and thus seems to be to big for download.
Is there another option? If not I'll wait until I have wlan connection.
@Adolf Klenk Sorry that we don't have the OTA for it, so you still need to download the firmware through a computer and then proceed the update.
@Support Dasaita Hiya, sure.
@Jason Man Hi customer, they are having Dragon Boat festival holiday now, would you kindly wait for a few days for their back and diagnose about the issue.
Hi, any follow up on this?
@Jason Man Please try update the latest version.
Vivid11(20240604): https://www.dropbox.com/scl/fi/1clw6dqa9zmxfr717uuwh/update.zip?rlkey=ltfea919b8ytclpytaqfjlser&dl=0
Hiya, just tried it, no difference
@Jason Man Have you wiped the data before proceeding the update?
Nope, I will give that a go first
@Jason Man
Please follow the instruction of how to update, note to wipe the datas.
Thanks, it seems to be working fine now!
Is there any way of making the panel on the right more transparent so we can see our custom wallpaper more clearly?
