Troubleshooting DAB+ Signal Issues on Your Car Stereo
  • If you are experiencing issues with the DAB+ signal on your car stereo, follow these steps to diagnose and resolve the problem:
    1.Check Antenna Placement: Ensure that the DAB antenna is correctly positioned. The recommended placement is on the front windshield. Proper placement can significantly impact signal reception.
    2.Ensure Grounding: The ground wire of the antenna must be properly grounded. This means it should be in good contact with the vehicle's chassis. A poor ground connection can lead to signal issues.
    3.Inspect Connections:
    USB Connection: Verify that the USB connector between the DAB module and the car stereo is secure. Loose connections can cause interruptions in signal transmission.
    Antenna to DAB Box Connection: Check that the connection between the antenna and the DAB module is secure but not overly tightened. Over-tightening can damage the connectors and lead to signal problems.
    4.Software Update: Ensure your software is up to date. Sometimes, signal issues can be resolved with the latest software updates. The latest version as of June 2022 can be found here.
    Note: If your unit is G12, you could go to APKInstaller > OEM to install the DAB+ APK.
    By following these steps, you should be able to resolve most DAB+ signal issues. If the problem persists, it may be necessary to consult with technical support for further assistance.
    Thank you for choosing our products, and we hope this helps improve your experience!
