Just started happening, not sure if its the result of an update to the firmware or MCU.
Head Unit: QCM6125
MCU V4.13a
Firmware: 20240713
Happens whe I select reverse or when stopping. I get the front and rear camera views when stopping and reversing (this is correct no issues here)
Anyone come across a setting that needs changing?
@Iain Sherrit There is a stetting under "Car settings" (check them all as i dont remember exactly where it is) for setting up the audio when reverse camera is active. You can select from "no audio" to "full audio" or just a "volume level decrease"
Its strange that when stopping the camera shows up. (if it is a normal behavior of your car i have no issues, but it sounds strange to me). Anyway probably it could be configured under the car configuration app or any other app related to the car that is available on your head unit system
@Iain Sherrit
Please try to do as follows:
Settings > Car > Extra settings > Reversing volume > On.
