Audio / sound does not work.
  • I am having a problem with audio, it does not work, in carplay, bluetooth audio or calls, not even key tones when I press home or back button.
    Any advice?
  • @LUIS GUZMAN
    1、
    In order to confirm the model&version that you got,
    please provide us with your valid order number / order details screenshot if possible.
    2、
    For better help, please tell us it happened from the beginning or after using for a while,
    and whether other functions can work except audio.
    3、
    Regarding to your issue, we suggest that you can try to do as ollows:
    1). Please check if you have connected the audio output cable properly.
    2). Please adjust the volume:
    Settings > Car > Factory settings(password :126) > Voice > adjust the volume > Apply > Exit > Reboot.
