Zlink (Apple CarPlay) Stopped working - WiFi won’t turn on and prior to the Apple CarPlay stopped working the audio is much quieter on Scout than Apple carplay.
@Matthew Boller
1、
In order to help you better, please provide us with your Order Number.
2、
For your information, it doesn't support to connect WiFi when you’re using wireless Zlink(CarPlay/Android Auto).
cuz the network access has been occupied by Zlink.
If you want to want to connect WiFi, please make sure that you have disconnected Zlink firstly.
3、
Based on your picture, we notice that your firmware is not the latest one.
Please check the tutorial below then try to do the update firstly.
Step1.
Step2.
Step3.
Step4.
Step5.
@Support Dasaita Any reason you are not providing the latest Vivid 11 update ??
telenav_vivid_rk3399_11.0_ota(20240604)
https://www.dropbox.com/scl/fi/1clw6dqa9zmxfr717uuwh/update.zip?rlkey=ltfea919b8ytclpytaqfjlser&dl=0
@Zeek World
The update file that we provided is the most stable version currently.
