@Antonio Catalano Thank you for your time ,please get in touch if you need any help.
@Antonio Catalano It was our pleasure here,keep in touch.
@Support Dasaita Dear DASAITA, problem solved. In particular I tried to install the NavRadio Basic application, from Play Sore, so I can understand if it was a problem of the native software module of the G12 or if it was a Hardware problem as you indicated. To my surprise I found that after installing the NavRadio application, the native radio listening software module of the G12 also started working properly. Therefore I report my experience so that I can, on your part, investigate the reasons why the software module of the G12 has such an abnormal behavior.
@Antonio Catalano
Thank you so much for sharing the information.
We will reflect it to our technical department.
