My Dasaita unit (used to be Vivid - now Scout) with Android 11 on a Toyota CHR 2006 EU has very strange behaviours after the passage from Vivid to Scout. In double screen the skip next and skip previous botton don't work at all (but they beep when pressed), also on autoradio start musicolet is loaded but it doesn't play music, or it goes at zero volume.
@Vincenzo Maio
@Vincenzo Maio
Based on your pictures, we notice that your firmware is not the latest one.
Please try to do the update firstly to see how it goes.
Step1.
Step2.
Step3.
Step4.
Step5.
