4 SWC Buttons Not Correct - 2015 Tundra & G13
  • I recently purchased and installed the G13 (model HA2220H2) for my 2015 Tundra.  At first, the only working SWC buttons were vol. +, vol. -, Up, and Down.  After reading other posts describing similar issues I went into Factory Settings > other and changed "Steering wheel keys assign" from SWC Key -> CAN Key.  After reboot and key study I now have more of the buttons working.  The only buttons still not working properly are Left, Right, Enter, and Back.
    Left and Right buttons do not register at all, but the odd thing is, Enter and Back buttons immediately close the key study opening the reverse camera (like I put the vehicle in reverse).  Otherwise, the reverse camera functions exactly as it should when I'm reversing.
    Toyota's wiring diagram shows these four SWC buttons (left, right, enter, and back) all coming off the same signal wire (SW3 / pin #24 on Toyota connector J139). The matching Pin #24 on the CB004 connector attaches to a blue wire leading to the canbus box.  For this reason, I suspect the issue is being caused by the canbus, settings for canbus, or a miswired CB004 harness.
    Also, Factory Setting > Canbus is currently set to 08 TOYOTA_CAMRY&RAV4(Simple).
    Please advise and help me resolve this issue.
  • Hi A H,
    The 2015 Tundra need to use the harness CB004.Factory Setting > Canbus is currently set to 08 is correct.
    Did you try to program the button of Left, Right, Enter, and Back?
    Step 1. Please go Settings > Car > Factory settings (password126) > Others > Steering wheel keys assign > Can key > Apply > Exit (Restart).
    Step 2. Please go Settings > Car > Steering Wheel Keys > start to program OR just open the App "Wheelkey Study" to program. We also attached a video showing how to reprogram the SWC keys for your reference, please check it out.
    Here is the studying video of steering wheel control
    https://www.dropbox.com/s/7hovrnq4uingkoj/%E6%96%B9%E6%8E%A7%E5%AD%A6%E4%B9%A0.mp4?dl=0
  • I already tried programming these 4 buttons.  Left and Right button do not respond at all.  Enter and Back immediately kicks me out of the key study and opens up the reverse camera image. It seems like they trigger the same signal as if I shifted the truck in reverse.
  • Video below shows failed programming attempt for left, right, enter, back buttons as described above...
    https://www.dropbox.com/scl/fi/8i6xs7fe82v7uugx6hwzq/4-keys-not-programmable.mov?rlkey=zfnmabxocorigaj3rnmr0jgtj&dl=0
  • @A H
    Hi A H,
    Thank you for your video,and we totally understand the issue you're having.
    In order to better follow up the issue with you on time,please get in touch with our Dasaita support Team email to get further help,and attached the Order details(Including Order Number&Unit model&Version): team@dasaita.com
    Thank you for your time and patience in this matter!
