hi, I have a px6 a11 dasaita. I try to setup BlueDriver ebd2 dongle but it does not recognize the Bluetooth device. The device is detected from my iPhone.
I see g12 latest support BlueDriver via MCU update and Bluetooth driver updates.
is there an equivalent fix for px6? If not can I upgrade to g12 image?
here are my device
@Philippe Marsteau
Hello customer,
For you concern, PX6 can't be updated to the G12.
Here is the MCU and Bluetooth of PX6 :
MCU 4.11 :
https://www.dropbox.com/scl/fi/c1xr7zpqpham59rjv4k61/hmcu.img?rlkey=efj9n5chzyr7omhll4eqv7b4b&dl=0
- Please download above update file via your computer/laptop.
- Please copy the file to the root directory of USB drive.
Bluetooth APK:
https://www.dropbox.com/scl/fi/um3zmkvtx81wejfkwulm2/bt1031p_update.bin?rlkey=16771kbsih5btwe0ts3a6qdsb&dl=0
- Please copy the file "bt1031p_update.bin" to the root directory of USB drive.
- Settings > Car > Factory settings (password : hctbtup)
Before I upgrade will this allows for using eb2 dongle (like blue drive) once BT and MCU is upgraded?
@Philippe Marsteau Sorry for the misunderstanding . The update is for the OBD2. It is a shame that the unit isn't suitable for eb2 dongle (like blue drive).
We remain at your service,thank you.
i meant OBD2 (BlueDriver). Typo on my end. However, is the MCU and BT above for PX6? Or for G12?
I own a PX6
@Philippe Marsteau It is for the PX6 . If it is the OBD2 ,you could try to update
Head unit is now bricked. Black screen and no way to restart it.@Support Dasaita any option to recover? This was after attempting MCU at your recommendation...
@Philippe Marsteau Hi there, we are wondering if you could scroll back the MCU to 4.04 to see if the radio could recover.
https://www.dropbox.com/scl/fi/9sdyk1k0hw0kleu3dbsd1/hmcu.img?rlkey=c1lkgeic6y900g0shpdquinoe&dl=0
Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select "Apply MCU from SD card or USB".
Pressing for 15s made the head unit start again. Since MCU never went through, it still runs same older version I had prior to attempting upgrade.
any idea why the upgrade failed when applying the MCU you sent?
@Philippe Marsteau
Thank you for your time an patience in this matter.
We have just been informed that MCU has been stopped updating.
Please keep the current version working on the unit. Don't update again.
We remain at your service.
@Support Dasaita so MCU was not for PX6 after all?
@Philippe Marsteau
It is for the PX6,but it doesn't supported be updated again.
As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices. Hope you could understand.
