G12 Qualcomm 665 in Rav4 with JBL
    Hello I have a 2016 Toyota RAV4 with JBL amp and subwoofer. I originally had the G10 Max10 head unit for it and used the rca adapter (pictured below). I recently bought the G12 Qualcomm 665 head unit for my car. Do I need to use an RCA adapter still? If so, do I use the same one I used with my old Max 10 Dasaita unit?
  • Hello.
    If your new G12 Qualcomm 665 head unit has RCA outputs, you can use the same RCA adapter you used with your G10 Max10. However, if the G12 head unit has a different output configuration or does not have RCA outputs, you may need to get a compatible adapter or cable. Make sure to check the specifications of the G12 head unit to confirm the output options before proceeding.
  • @Michael Uribe
    Hello ,
    The RCA is the same as the MAX 10 and G12,here is the connection for reference
  • @Harsh Maan Thank you for your kind support so much.
