Hi
I tried installing the Vivid11 update and MCU as described here https://www.dasaita.com/community/forum/topic/126757/tundra-vivid11-black-screen
but now when I turn the stereo on the screen is black and there is a beeping sound every x seconds
tried reflashing but it goes from 65% to 100% and after that same problem as before
@Support Dasaita also the buttons don't light up but beep when touched
@Martin Karbon
This MCU and firmwar isn't for your unit.
Please find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click. Please find the tutorial video below:
https://www.dropbox.com/s/wk7djnp4ar4omxt/1%3B%E4%BD%BF%E7%94%A8RST%E9%94%AE%E6%81%A2%E5%A4%8D%E5%87%BA%E5%8E%82%E8%AE%BE%E7%BD%AE%E6%96%B9%E5%BC%8F.mp4?dl=0
For the buttons,please try to Setting>Car>Factory Setting(Password:126)>Other>Panel Led Control> Choose "By Power""By headlight""by headlight and power> Click “apply”
The screen is always black so I cannot access any menu on there. I managed to connect via pc/usb: will it work there? I installed the firmware and mcu
@Martin Karbon
Please provide your order ID so we could locate the model and offer you a possible solution.
It's Amazon order # 408-2136759-5636329
@Martin Karbon Please check your email and we sent the suitable system to you.
