Whether I place the sound source in the front right, rear right, front left, or rear left, the sound comes from the rear and slightly to the left. When I adjust the position and release my finger, the sound disappears for a moment, but the balance between the front, back, left, and right remains the same.
Also, I can't adjust the sound quality at all. Is there any way to solve this problem?
Hello customer,
Since you updated the system to vivid 12 ,it doesn't fit the DTS on your unit properly.
We will send the suitable one to your email later,does your car come with factory amp?
Thank you for your reply. I will keep the amplifier as standard. Thank you in advance.
@osamu nonaka No problem, for any other helps,please get in touch.
The amplifier is standard but I can't control the sound field. Is there a solution?
@osamu nonaka Please check your email to update the new firmware and MCU
Thank you. I checked my email and downloaded the two updates.
@osamu nonaka Thank you for your time.
