Hallo,
Ik hoop dat u mij kunt helpen.
Na de update crashte Google Playstore steeds opnieuw.
Ik heb deze update uitgevoerd.
MAX10-versie : zorg ervoor dat uw apparaat PX6 Android 10 is
HA3_rk3399_10.0_ota(20230803)
Heeft u hier een oplossing voor?
I have another question, how can I get this home screen.
After the update I lost the car logos.
Do you perhaps have the Nissan logo?
@Arnold Dolman
Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
Here is the boot logo:
Good morning,
Thanks for your quick response.
I did the update because my iPhone wouldn't connect to wifi.
If I go back to factory settings now, I'll have the same problem again?
Kind regards
@Arnold Dolman
Please try to do the factory reset to firstly to see how it goes.
Hallo,
Het lijkt nu te werken. Thanks for thinking along
