Microphone issues!! Plz help
  • @Support Dasaita il problema c'è sia con microfono esterno collegato e sia con microfono esterno scollegato.
    Io credo che entrambi i microfoni lavorano insieme. Sono entrambi attivi
  • @Emiliano Di Nella
    Ciao, abbiamo inviato il messaggio alla tua email, controlla e vai avanti.
    Con l'avvicinarsi del capodanno cinese, contatta la nostra email " team@dasaita.com " ufficiale per ulteriore assistenza.
    Grazie
  • Hello, I had to remove the 13.3 screen to make some connections behind the double din.  After putting things back together the screen does not respond touch.  I pressed the reset but still no response.  Any idea what I need to do? My unit is the vivid 10 universal 13.3PX6 4g+64g
    Also, are there updates for this unit?  I purchased in in 2022.
  • @Fred Traylor Please kindly try to use a mouse to calibrate the touch screen under the video instruction below.
    https://youtu.be/yaRKoQb1jlc
  • @Support Dasaita Yes, thank you!  The mouse worked but I had to do a factory hard reset.  All is well now!  Are there any updates for this unit?  I've had it nearly 3 years, I haven't done any updates at all.
  • I've also been having this issue for a few months now, the only fix I've seen anyone report is to take apart the unit and desolder the internal mic, which seems crazy.
  • @Ben Bowcott
  • @Fred Traylor
  • @Support Dasaita  On my G13 the call quality is poor and after a few tests I've noticed that the microphone used is the internal one, even though I have the external one connected. Some videos on YouTube show the option to choose which microphone to use in the settings, but I can't find that option on mine. I don't know if this is the solution to the poor call quality, but it should be an improvement.
    Order SP-DA6575 and purchase date January 10, 2025.
  • 1
  • 2 / 2
