No wrangler 2019
  • Wrangler ac not working after plugging the can bus into unit. Pull the can bus out and ac works. Please help.
  • @David West
    Thanks for your message.
    For further confirmation, please tell us if the AC information can work without connecting CanBus box.
    Picture: Settings > About Machine > Model; Android Version; Build Number; MCU version.
    The front&back side clear photo of factory radio.
    Yes the AC works perfectly fine without the CanBus box plugged in. It stops working as soon as i plug it in. The ac lights on the dash start blinking and it completly stops.
  • @David West
    Could you please assist to provide the below details as well?
    So that we can forward it to our technician for further advice.
    Without plugging the CanBus box, can other functions(Steering Wheel Control/ Backup Camera/ Amplifier etc.) work normally?
    This issue happened from the beginning, or after using for a while?
  • @Support Dasaita  no the radio doesn't work at all unless I plug the can bus and that's when the ac stops working. But when the can bus is plugged in the radio and steering wheel controls work perfectly fine. This issue has been from the first time I've installed it.
    purchase order is from Amazon, 113-3332152-0771446 date was November 22 2024.
  • @David West
    Thank you for your response.
    —— "ac stops working"
    We'd like to know if you mean the AC information cannot display on the headunit and "Ac" App.
    If possible, could you please record the video about AC issue then send it to our mail?
    So that we can learn the situation and offer the solution better.
    📧Email: support@dasaita.com
    Please make sure CanBus option is NO.78:
    Settings > Car > Factory settings (password :126) > CanBus > Canbus  > 78 > Apply > Exit > Reboot.
  • Can bus is set to 78 and all settings shown above. still no hvac.
    the physical ac controls are blinking and does not work when the knobs are changed. The same goes for the controls on the new radio.  Email sent with a video.
  • @David West
    To better follow up the issue with you,let's chat on the emails.Thank you!
