I have a G13 unit and have included a pictures so you know the version.
I have found 3 apps that include TPMS:
I want to have TPMS sensors on all 5 tires (including the spare). Only one of these apps shows the spare:
There are 3 apps in the G13 unit. Do any of them work with the OEM TPMS sensors?
If not, can I get external Dasaita TPMS sensors that do all 5 tires? Or can I get internal Dasaita TPMS sensors that do all 5 tires?
One app shows all 5 tires but the other 2 apps only show 4 tires. Do all the apps support 5 tires or only the one showing?
Que alguien responda al compañero. Yo también me uno a la pregunta, sobretodo saber si alguna de las apps TMPS nativas funcionan con los sensores OEM, porque en videos de YouTube parecía que sí funcionaban. Yo no lo consigo, incluso probando todas las opciones de la que se ve si activas TMPS en el menú 126
Thank you Dani for jumping in. I hope someone will provide an answer.
@Steve Toeniskoetter
Hi Steve,
Do you purchase our brand Dasaita external tire pressure?
Hello. No, I did not buy the external tire pressure sensors. I would like to but I don't see them for sale any longer.
Hello. I just noticed that the TPMS sensor page has a selector to click to get the external sensors.
I watched the video, and just now ordered the external sensors.
Hi Steve,
I was wondering the same - are the TPMS readings just supposed to show up or does one have to buy a sender/transmitter ?
From the dialog it seems you have to buy the 4 valve stem sensors and get them installed at a tire shop since it requires removal of the tire from the rim and rebalancing. The receiver then plus into the system for a live display of the tire pressure.
I was looking for a way to tap into the OEM sensor signals - given the silence on this topic it does not look like it is possible ?
Hi Har,
I bought the TPMS sensors from this link:
https://www.dasaita.com/products/dasaita-tpms-app-good-quality-universal-car-tire-pressure-monitoring-sensor-external-system-real-time-for-car-stereo-player
When you're in there you'll see an option to choose either internal or external sensors:
You described the internal ones, where the tire shop needs to install them, but I bought the external ones.
First I plugged the receiver into the USB port of the G13 unit. Then I started putting the monitors on each tire, and within seconds the app was displaying the pressure for each tire.
You need to use the middle app from this screenshot:
It's working great. I'm not 100% convinced about the external monitors longevity but I want to do 5 tire rotation and I would have had to remove tires to get the internal sensor off the spare, and that is too much expense.
Let me know if you have other questions.
Har,
I should have included photos of the app.
I put it on my home screen in the lower middle:
And here's what it looks like when I open it up:
I tested it by deflating one of the tires, and it gives an alert you're not going to miss. Also you don't need to have the TPMS screen up - it will alert you no matter what screen you're on.
Thank for sharing your shopping expereience so much. The external TPMS supports to replace battery: CR1632 lithium battery@Steve Toeniskoetter
NEW MEMBER here. Without this module; is TPMS staus rendered useless even in the digital cluster behind the steeringwheel?
Justin,
This module doesn't affect the digital cluster behind the steering wheel. That will continue to work normally with the factory TPMS sensors installed inside your tires.
I have a Tacoma and am doing 5 wheel tire rotation. My problem was the Tacoma only supports 4 factory TPMS sensors, so when rotating in the spare I would need to have the sensors reprogrammed, and that isn't cheap.
I bought this module with the external sensors because the sensors screw onto the tire valves. This makes it simple and cost-free when doing 5 tire rotation, because I just move them to the correct tires.
@Steve Toeniskoetter Thank you for that. I don't need the head unit to tell me this. Glad I didn't jump the gun on that option. I appreciate your reply.
