I really enjoyed my purchase of the Dasaita Android 12 Car Stereo for Nissan Qashqai 2014-2020. But now for two weeks the car stereo wont start up by itself. It only starts up if i press the reset button and then shuts down! I don't know why??? I will put a video of this please review it and give me a solution. I payed a lot of money even for the best version with 8G+256G. I am currently driving now with no sound, no radio, no maps and no camera's. I even tried to open up the car stereo en checked the wires, nothing works..
A few other points:
- Before when i had no black screen the DAB+ internal NEVER worked like it should.. Always stuttering not enjoyable at all.
- The internal mic did work at first but was very bad. I can hear people but they can not hear me with desent quality. I installed the external mic that came with the car stereo. It did not work..
I really like the product but some of these things need to be fixed ASAP..
Thanks for your time..
@Mohammed Tuncer
Hi Mohammed,
Please update the Firmware & MCU to the latest version via the link below,here are some tips to help you get the work done:
①G12 Version:Make Sure your unit is QCM6125 Andorid 12
zst27_sc138_12_G12(20241126)
②4.12b MCU
1.Please download ①&② document through the link via your computer/laptop.(Do not rename and Unzip the file)
2.Format the USB drive before copying the Update.zip & hmcu.img file to it, then insert the it to the USB cable.
3.Find a pin, press and hold the RST button for 10 seconds to see if you can enter the factory setup page, if you can, select system updated ;
If it not work,please kindly get back to us.
Today i tried many times but it seems not to work yet..
I formatted the USB to FAT32 and loaded the files into the USB.
I put the USB into the car stereo.
Loaded up but it says E: footer is wrong. E: verification failed, E:error: 21
I dont know if the unit is correct? In the picture i send you it says MODEL NO: HA225
Please look at the pictures and video i have send you.
Video:
I hope we will get succes.
Thankyou.
|||UPDATE|||:
The system update with the USB was installed. I needed to extract the file on the usb and leave the Update (zip file) on the usb so not the map it was in. But!! I think you gave me the wrong update file because before everything worked very good now almost nothing works..
https://www.dropbox.com/scl/fi/retfjhagone67hrwvktzm/WhatsApp-Video-2024-12-25-at-22.19.10.mp4?rlkey=gb5htn1ymd501fsyu5o7scm6h&st=62v00pon&dl=0
- The menu loads up and i can scroll and go into menu's now
- Carplay = Not working
- Wifi = Not working (keeps crashing)
- DAB+ = No DAB+ icon (I have internal DAB+)
I've looked in the menu's en saw canbus 10 NiSSAN_2013TEANNA(simple)
Before it was Nissan Qasqai so i think you guys gave me the wrong update??? Can you please give me the right update model number HA5225 for Nissan Qashqai 2015 maybe the latest one?
Thankyou.
@Mohammed Tuncer
Hi Mohammed,
1.A clear photo of the stereo's Build Number.
No worries,the firmware is correct for Android 12.
Please go to the "Apkinstaller APP" to re-install the DAB apk.
Regarding the Carplay& Wifi issue,please go Settings>car>Apple Carplay/Android Auto>disable it.And then try to make the unit connected to the phone hotspot to see how is the wifi work.(Provide a video of the process would be great)
Thank you for your time and patience in this matter!
Happy New Year for Dasaita!
Down below you find ''A clear photo of the stereo's Build Number.'' and ''A clear photo of the stereo's MCU version.''
After i made the video i downloaded the Dab+ app with the apk installer, this worked for me for Dab+
The unit connected just ONE TIME randomly like normal with wifi and carplay but most of the time i doesn't work.. Wifi freezes and carplay will not connect with phone but the bluetooth is connected.
I made a video of the process the link is down below:
https://www.dropbox.com/scl/fi/thsk3a5rxelqir9maza08/5df8af45-2708-4c8f-bc9e-b154a9c63349.mp4?rlkey=3d0l3rzcgnx77euef5pvop11z&st=ny3o6ubw&dl=0
Thankyou.
@Mohammed Tuncer
Hello, thank you for sharingd details with us.
Please try to find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
We've forwarded the issue to our technical department and keep you updated once we received their response.
Thank you for your time.
I'm sorry to say but i already have reset the car radio many times. This is not really a solution..
I hope to hear from you soon.
@Mohammed Tuncer Hello, thank you for your time and patience. For saving your time ,we sent a message to your email.Please feel free to check it.
