I recently bought the Dasaita G13 for my 2019 Honda HR-V.
Now, I have the problem that I can't change any settings in the car menu, just like described in this thread:
https://www.dasaita.com/community/forum/topic/122492/inaccessible-car-control-settings
Which CanBus version do I need to select to get these settings to work?
My second issue concerns the lane trajectory in my rear camera. I am using the original camera from my car, and everything works great—including the lane trajectory. However, the only problem is that the lines are not accurate. For example, when I try to reverse into a parking spot, the trajectory lines indicate that I should be able to drive straight into it, but in reality, the car does not follow the indicated path.
I have tested all available options (130° and 180°), but the accuracy of the lines remains an issue. Is there a way to correct these guidelines? With the original head unit, I could fully rely on the trajectory lines to park precisely, but now they are misleading.
Third question, is my version the newest one?
Best Regards
Milan
