I have Dasaita Vivid 11 PX6
I have a problem with the rear camera.
Since I bought the device, the vision of the rear camera is not good, especially at night, it is very grainy.
I checked the wiring and it is correct.
With the multimedia equipment that the Toyota CHR car had, the camera was perfect.
@Fernando José Fernández Álamo
For your information, our unit supports HD resolution.
If your original camera resolution is lower than our supported resolution,
then the image quality will also be lower accordingly after installing our unit.
My camera is Full HD.
The problem is only in night or low light.
Is possible to be solution update firmware???
Other people with my car not had problem with grainy???
Thanks.
Photo/Video about the rear camera issue.
Please check the firmware update tutorial below then give it a shot.
System Firmware-Vivid11:
https://www.dropbox.com/scl/fi/9fkhng2srynadlzvohbc6/update.zip?rlkey=jqnm8ksr6althxiq45w7a35ld&dl=0
Hola, ya he actualizado el sistema con el nuevo Firmware.
En los próximos días veré si la cámara trasera se ve mejor de noche.
Ahora he perdido todas las APP que tenía instaladas en el dispositivo.
Como se carga la copia de seguridad??? Solo encuentro opción de hacer copia de seguridad pero no veo la opción de cargar copia de seguridad que tengo hecha en mi cuenta de Google.
Gracias.
