Scout new firmware bugs
  • New scout firmware loads and freezing after activation had to factory reset. After Factory reset screen stuck and wont allow me to go back or exit screen
  • @J Irving
    Regarding to your issue, we suggest that you can try to do as follows:
    Please try to press and hold the RST button by pin to see if you can enter the factory setting interface.
    If YES, please select "Wipe data/factory reset" > "Factory data reset" and reboot the unit.
    We have attached the video for your reference, please check it below.
    https://www.dropbox.com/s/wk7djnp4ar4omxt/1%3B%E4%BD%BF%E7%94%A8RST%E9%94%AE%E6%81%A2%E5%A4%8D%E5%87%BA%E5%8E%82%E8%AE%BE%E7%BD%AE%E6%96%B9%E5%BC%8F.mp4?dl=0
    Please remove all of cables/harness and then plug again.
    And please make sure all wiring connections are correct and no loose situation when you replug it.
