Screen Dimmmer
  • Hi , i have the G13 for my 2016 Toyota Tundra.
    Whats the best way to turn off the scrren or turn down the brightness for night driving?
    I use the dimmer icon on the top right of the screen (see attached photo) but the screen is still to bright at night.
    Tom
  • @Tom Elam
    Hello, Tom.
    Please try to adjust the brightness as follows:
    Settings > Display > Brightness level/Night display.
    Settings > Car > Factory settings (password: 126) > Other > Brightness.
    There is a touch screen turn-off button.
    If needed, please refer to below video to study the button:
    https://www.youtube.com/watch?v=111pQ_c1iPw
  • was able to set the screen timer to 1 minute and get it to turn off (Screen saver)
    The time and todays date will appear on the screen and move around.
    The time is set to military time however.
    How do i change the time to standard time for this specific screen dim/screen savor, whatever you call it?
    I already have the time set to standard as it appears correctly on the home screen
    It just shows military time when the screen shuts off.
    Tom
  • @Tom Elam
    Please confirm the setting:
    Settings > System > Date & Time > Use 24-hour format > Disable.
    Regarding to your issue, we suggest that you can try to do the factory reset firstly:
    Settings > System > Reset Options > Erase all date(factory reset).
    If no luck, please go Settings > About Machine,
