PX6 - Android auto wireless with Android 15 Pixel 8a
  • Dear @support,
    Does PX6 unit, updated to scout and Android 11, supports Android Auto wireless?
    When I connect my Pixel 8a via Bluetooth to my PX6 unit, I see android auto notification on my smartphone saying "search for Android auto in progress" but if I start Android Auto app on my head unit I see the zlink splash screen but nothing happens.
    If I use USB cable I can use android auto on my head unit.
  • @Mcgyver83 Hi,
    It may the unit can't compatible with your phone.
    Could you please confirm if the android Auto version is the latest one?
    Please go to Settings>About machine and provide the following version information:
  • @Support Dasaita below requested info.
    Android auto app on my pixel 8a (android 15) is latest.
  • Vivid11(20250217):
    https://www.dropbox.com/scl/fi/9fkhng2srynadlzvohbc6/update.zip?rlkey=jqnm8ksr6althxiq45w7a35ld&dl=0
    1.Download the documents ①&② through the link on your computer/laptop.
    2.Format the USB drive(FAT32 Format)before copying the Update.zip & hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • Ciao @Mcgyver83 , stavo riscontrando il tuo stesso problema (ma con PX6 Android 10 e Pixel 7a) e dopo aver provato diverse soluzioni senza successo, ho scoperto che il problema era dovuto a Zlink5. Quindi ti consiglio di provare questa versione di Zlink3
    HCT Firmware PX6 Android 11  Make Sure your unit is PX6 Andorid 11
    HCT8_rk3399_11.0_ota2820220412
    Saluti
  • Hi Enric, I have a similar problem and I saw that you solved it by using a much older version. Can you tell me if the maps on Google Maps are displayed correctly? In the previous versions with Vidid the resolution was excessively high and the letters were very small. Do they look good in the version you have installed? Could you send me a photo please?
  • Salut Manu,
    I know what you mean about resolution, It happens the same to me with Vivid and Max versions (also the icons in the left side are too small with AndroidAuto), in my case with HCT version the size is the right one... If I don't forget it, I'll attach a photo tomorrow
  • @Enric Subirana
    I've already installed it and it works much better, the vivid launcher is very invasive and doesn't allow you to configure almost anything. Now I'll look for a launcher that looks nice and try to use another program as default for the radio because the one it comes with is very basic and ugly. Thanks for your suggestion
  •  @Enric Subirana
    I love how this firmware works, but I have a problem: when someone calls me on the phone, I hear themselves with a delay. Did this happen to you? Have you solved it? I've thought about updating the ZLINK version to see if that fixes it. Do you have any suggestions?
  • @Enric Subirana grazie.
    Non riesco a trovare il link al file scaricabile di Zlink3.
    Potresti provare a metterlo qui?
  • @Support Dasaita it's possible to know the changelog for this firmware version?
    Vivid11(20250217)
  • I've tried updating Zlink from the same app and with another downloaded app, but it's not working. I finally installed the MAX11 version, and the echo issue is resolved, and it doesn't have the same problems as the Vivid version. I'll try it, but of the three, it seems to work best for my needs.
  • @Manuel Bernet what do you mean?
    There is ZLink for Vivid, another for Max11?
  • HCT Firmware PX6 Android 11  Make Sure your unit is PX6 Andorid 11
    https://www.dropbox.com/scl/fi/fn309fje0c4c1l6bql0n4/HCT8_rk3399_11.0_ota-20220412.zip?rlkey=3beoqpk3oag4nj363gbxlmy39&dl=0
  • @Support Dasaita what is this?
    Full firmware update or ZLink?
  • Last version for our Dasaita (2025 02 17) Itryed today and work, but I use too
    https://xdaforums.com/t/appswitcher-v3-smart-swc-launcher-for-junsun-xtrons-ossuret-hizpo-and-similar-devices-incl-autostart.4593865/
    Please update the Firmware to the latest version via the link below,here are some tips to help you get it done:
    telenav_vivid_rk3399_11.0_ota(20250217)
    1.Please download the file though the link via your computer/laptop.
    2.Format the USB drive before copying the Update.zip  file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • @Manuel Bernet
    20250217 work for your unit now right?
  • @Support Dasaita This version is the most stable I've found. Everything seems to work fine, except for some issues connecting to the Z-Link wirelessly, but the hands-free sound is good. I use the NavRadio because it works better than the original, especially for automatically changing frequencies when traveling. The track and radio buttons work with Android Auto, which was missing in the previous version. The Android Auto resolution allows the lyrics to be displayed correctly. I don't understand why it isn't published in the firmware thread; luckily I found it while reading the forum.
  • @Manuel Bernet
    As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices.
    If it is not necessary, we do not recommend to upgrade.
  • @Support Dasaita what do you mean with "new system"?
    @Manuel Bernet where did you found this new firmware version?
    I'm looking for a way to have android auto wireless: I red in message above that an older version of Zlink should work but I cannot find it.
    @Support Dasaita which firmware I should install?
  • 1 / 2
  • 2
