Boot loop android 13
  • My device is in a strange boot loop and when I try to go to the factory reset menu, it won't let me use the keyboard to put the 3 digit pass code in and then reboots again. Please help! It's the unit for the rav 4 2019-2024
  • Hi Myles,
    Here are some tips to help you get it done:
    zst27_sc138_13_(20250226)
    https://www.dropbox.com/scl/fi/hskmzj675wwjh9gs67emi/update.zip?rlkey=8td73qmw1bp0zwqud98b3e8hx&dl=0
    1.Download the documents  through the link on your computer/laptop.
    2.Format the USB drive(FAT32 Format) before copying the Update.zip file to it, then insert it to the car's USB cable.
    3.Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select system updated ;
