Change DPI for Android Auto
  • Good morning, is there any option to change the DPI in the Zlink app? My radio version is QCM6125_20240903-1414 (I saw that there is a 20250311 version—should I update?), and my Zlink version is V5.4.58.
    From what I found online, some versions allow changing the DPI in the Zlink app settings. It seems that the current DPI is set to 160, which, with a resolution of 1920x720, makes the interface too small. It would look better at DPI 240 or even around 320. When using CarPlay, everything looks fine.
  • @Ariii
    Thank  you for your contact.
    For the DPI, please take a picture of showing your android auto screen.
    Please also take a picture of Settings>About machine> Build number
  • Hello, I took two photos comparing Apple CarPlay to Android Auto. On the Android image, I overlaid the visible range from CarPlay and also measured the default zoom level range: in CarPlay it's about 950 meters, while in Android Auto it's around 2100 meters. Of course, you can zoom in on the map, but street names and other labels still remain quite small.
  • @Ariii
    Thank you for your details.
    For the issue of android auto , we've updated the issu in new version.
    Please try to update.
    G13(20250311)
    1.Download the document through the link on your computer/laptop.
    2.Format the USB drive(FAT32 Format)before copying the hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • Good morning, I updated the radio with a data wipe, the Zlink app updated from version V5.4.58 to V5.4.99, but nothing changed at all, the DPI remained the same.
  • @Ariii
    May we have a picture of the androdi auto screen and a picture of your build numer(Settings>About machine>Build number) so we could forward to our technical support to beeter check ?
    We appreciate your time so much.
    Kind regards,
    Dasaita
