Warm Notice:
If your system is working well, please do not upgrade it !!!
Because the upgrade is risky, it might lead to CRASH, BLACK SCREEN, OR SYSTEM ERROR;
Unless there is a major bug in the car system, it unable to be used normally.
At this time, you can choose to upgrade the system to solve it.
Please contact your dealer to ensure you are selecting the correct firmware and following the appropriate update steps.
(You could refer to topic: How to update firmware)
Android 13 Update
G13 Version:Make Sure your unit is QCM6125 Andorid 13
zst27_sc138_13_(20241022)
https://www.dropbox.com/scl/fi/d4ey294jqtlfucjc0q61k/update.zip?rlkey=qhg8wexxj4rew9q9wr91r19ip&dl=0
Android 12 Update
G12 Version:Make Sure your unit is QCM6125 Andorid 12
zst27_sc138_12_(20240812)
https://www.dropbox.com/scl/fi/xgeqo49jd33fzxvab92k5/update.zip?rlkey=348xdnr3e0ugks99in8y9rdgm&dl=0
Vivid12 Version(beta version):Make Sure your unit is QCM6125 Andorid 12
telenav_scout_SC138-12.0_ota(20240410)
https://www.dropbox.com/scl/fi/0fi69hmxo19ljrq2x5mj3/update.zip?rlkey=f9bnfwo1h95m3f0wrb4zh5i1c&dl=0
Android 11 Update
MAX11 Version:Make Sure your unit is PX6 Andorid 11
HA3_rk3399_11.0_ota(20230608)
https://www.dropbox.com/scl/fi/ye2ia7nmb9d7cn7z9n424/update.zip?rlkey=m14rlfbbz5fdig0mpjmn8ycw8&dl=0
telenav_vivid_rk3399_11.0_ota(20240913)
https://www.dropbox.com/scl/fi/pnsjj03lhqsue7pjsgi42/update.zip?rlkey=qjhhdbhtzccaru1v45nrwbxj7&dl=0
HCT Firmware PX6 Android 11 Make Sure your unit is PX6 Andorid 11
HCT8_rk3399_11.0_ota2820220412
W11 Version Make Sure your unit is PX4 Andorid 11
HA3_rk3566_11.0_ota(20230103)
https://www.dropbox.com/s/ftfec79f3lg9cro/update.zip?dl=0
Android 10 Update
HA3_rk3399_10.0_ota(20230803)
Vivid 10 Version: Make Sure your unit is PX6 Andorid 10(The left widget's map could be customized, suggest Google Map and Scout Map.)
telenav_vivid_rk3399_10.0_ota(20240126)
https://www.dropbox.com/scl/fi/9whz1p3ovge2ga2g75m8x/update.zip?rlkey=n9yitv3tnx3vzgaixesru94s8&dl=0
scout OS3.5.6
https://www.dropbox.com/s/8mdkldq34ccp53z/update.zip?dl=0
Scout Maps
(homepage maps only have for US CA AND MX) copy the TelenavMapData folder to unit Flash folder
https://scout-ivi.s3.amazonaws.com/map/USAM/23Q1/TelenavMapData.tar.gz
Scout Maps APK
HCT Firmware PX6 Android 10 Make Sure your unit is PX6 Andorid 10
(PX6 android 10) HCT8_rk3399_10.0_ota(20220412)
V10 Version:
(PX5 android 10)HA3_px5_10.0_ota2820220401
S10 Version :
HCT7_px30_10.0_ota(20220719) https://www.dropbox.com/s/h4n0ubi45jfcdg3/HA3_px30_10.0_ota%28S10--20220719%29%E5%8D%87%E7%BA%A7%E5%8C%85.zip?dl=0
Android 9 Update
V940 Version :
PX5 HA_px5_9.0_ota(20201022)
MAX6 Version :
PX6 HA2_rk3399_9.0_ota(20211023)
https://www.dropbox.com/s/h8zjji07bn8mopo/HA3_rk3399_9.0_ota%2820211023%29.7z?dl=0
Android 8 Update
V840-8 Version :
Other Android Update
V500 Version:5.1 System
KR3188 5.1 UPDATE HA (20170307)
https://www.dropbox.com/s/xhanlup10f8up16/new4_rk3188_5.1%2820170307%29%2801%29.zip?dl=0
BMW HD Series
https://www.dropbox.com/s/06kib8etsatpj9v/Ksw-Q-Userdebug_OS_v3.4.2-ota.zip?dl=0
Mercedes-Benz HC Series
https://www.dropbox.com/s/am1f0e1tk1vo7b7/Ksw-Q-Userdebug_OS_v3.4.2-ota.zip?dl=0
Accessory APKs: (Go to APKinstaller to install the APPS.)
CP005 Upadte
CP006 Upadte
CP007 Upadte
USB DAB(version:H4.4.27)
https://www.dropbox.com/s/iuco52c48o0wp3f/DabPlayer-H4.4.27.apk?st=c83mffhi&dl=0
Integrated DAB
https://www.dropbox.com/s/lgplnpezjwkrtx9/YHX-DAB%2BW8-S1.38.zip?dl=0
USB Carplay
autoplay https://www.dropbox.com/s/3xcyf3sk7vfnic1/AutoPlayBox_2021.05.28.0857.apk?dl=0
USB TPMS
https://www.dropbox.com/s/8kfdytcbnclgtab/Tpms-v59.apk?dl=0
