Mitsubishi Outlander 2014-2019
  • Mitsubishi Outlander 2014-2019
  • Hi, it's my first time posting here.
    My enquiry is about 2015 mitsubishi outlander phev (preface lift).
    I was wondering if you have any information about what all the options do in the factory settings section.  I am also unable to change my vehicle settings through control app and my original unit had dab.  I'm unable to get dab to work on the Dasaita unit.   Could you please tell me how I can fix this.
    Many thanks
    Thane
  • @amazon which canbus do I use for 2015 Mitsubishi Outlander phev?
    Thane
  • @Thanendera Senthilkanthan, i had the same problem here, the car error is U0245, meaning the ECU cannot discuss with the CanBus adapter. I changed 3 different CanBus adapters, MT-SS-02, MT-SS-07 and RP5-MT-002. From the secret menu, i switch between Outlander Simple to Pajero/Outlander the can bus line, no luck !
    With MUT III, i made a canbus repair/check procedure, the issue is still there.
    @Dasaita Official, can you please provide us some support here?
