Hello anyone with the same problem as mine. I recently installed Dasaita HA225-MAX10-CP, CANBUS008. I have a problem with my 360 view graphics alignment for Nissan Qashqai Ti 2016 model. I tried using different canbus setting but it didn’t work. Your help is highly appreciated.
hola , lo he intentado así como dice y me dá error , dice no encontrar archivo o directorio, mi equipo un px6 max 10 con firmware de mayo 2021 y mcu abril 2021
Hallo irgendwie kann ich die Datei nicht finden ( dmcu) Update hab ich runter geladen.. 🤔 Und muss ich es entpacken oder nur die gepackte Datei auf den USB Stick machen 🤷♂️ Dankeschön im voraus
I'm starting to worry that questions are being ask but not answered. I am still thinking of buying a dasaita head unit and now worried that the support isn't there
buonasera non riesco ad aggiorare il firmware del mio max 10 in nessun modo.una volta formattata pen drive in fat32 carico i file dmcu e update ma anche se compaiono i messaggi di aggiornamento si blocca all'avvio aggiornamento per errore file.
@Quick Yuan i was able to update the MCU to 3.78 using your instructions but am trying to install scout and the stereo is not doing anything when I tap on the system update button. I also tried vivid and it's the same problem. I have a px6 max10 in a 2012 Toyota sequoia. What am I doing wrong?
Edit: i renamed the file to "update.zip" and the system found it. Only problem is that it won't install it because there is an error "footer is wrong" and "signature is not valid" . I don't know. I guess sill keep trying.
@Iker Gomez that's exactly what it was. How did that even happen? Thank you so much. You totally saved me from the craziness i was going to try and do to fix it!!!
