I have the Dasaita MAX10 Single Din 10.25" Universal Car Radio.
It came with an external microphone, but I cannot see where to connect it.
Please can you help?
hi
there is a MIC input with the dual USB cable
@Quick Yuan Thank you for the response.
There does not appear to be a mic input with the dual USB cable I have.
Please see photos below.
The label does say "MIC" though.
Hi
please contact the seller to send a free dual USB cable with MIC input , this cable must be made by mistake
@Quick Yuan i also did not get a dual USB cable with mic input
@Ara Gureghian hi
I send you massage , please check
I did not get the cable with the dual usb and mic plug either with my unit and the hands free clarity sucks without external mic. How can I get that cable?
as with all other customers, dasaita has delivered the wrong cables and is now not sending new ones.
@Pat Ti I also have no mic port to install my mic. Also, none of my steering wheel controls work even after set up. Is there a bug fix? If so can you supply a link to the update?
it was a terrible service from dasaita. i order direct by dasaita and received the wrong cable without microphonejack. they never answer on my requests or send me a new correct cable 😡
i take this topic back to the top. dasaita has not responded for 2 years that they have delivered the wrong things and therefore the microphone does not work. the correct cable cannot be bought either. very annoying!
