I just installed the Dasaita scout 10 toyota 4 runner head unit and the home screen is blank on the side that should be showing the navigation. The right side shows the correct screen. The nav works if I go to the app directly. Any help would be appreciated.
@Todd Klipfel
hi
there is 2 way use the scout maps
1 connect to the wifi
2 download the offline maps , and copy the folder TelenavMapData to unit Flash
Scout Maps link
https://www.dropbox.com/s/4k8orky5mn5th0h/TelenavMapData%20%281%29.zip?dl=0
do you have it for the vivd 10 andriod
@Quick Yuan
I downloaded maps for SCOUT and after packing there are two folders _MACOSX. And TelenavMapData. Do we transfer these two fobers to FLASH memory? Are these maps for the whole globe, because I'm from Polish and I don't know if it will work. Please help and thank you.
