When will it be a full MAX11 Vivid image to flash instead of MAX10 Vivid?
@Zeek World if you are already into android 11 you can use the normal A11 OTA updates to change from max11 to vivid 11. Here you are a vivid A11 OTA:
https://www.dropbox.com/s/xoy332fcx7t7bfn/telenav_vivid_rk3399_11.0_ota%2820220413%29.zip?dl=0
If you are still on A10 you can upgrade to A11 with the Max11 full image and then use the above OTA to move to a Vivid rom
Thank you, I will give it a shot.
I'll have to install, MAX11 and run the vivid ota, thanks 👍
