Toyota Rav4 TPMS
  • Hello
    Ive had my head unit for nearly 2 years now, its the max 10 px6.  I have the TPMS app on the unit but no data shows up. Ive just read another post saying the same, My question is should this work with with the factory fitted tyre valves through the canbus or do i have to upgrade the valves. My rav does have factory fitted TPMS, i get a light on the dash when the tyre pressure is low.
    Andy
  • @Andrew Sloane as fat as I know. The TPMS app just works with Dasaita TPMS kit.
    The app just appears there as on the factory settings is enabled the settings TPMS on the first tab for options
  • Thats a shame. Im not that desperate to use it to swap all my tyre valves.
  • @Andrew Sloane I bought the EXTERNAL tpms from dasaita. That enables me to retain the oem toyota valves. Removing the toyota valves will result in a permanent low tire pressure warning light on the dash. The external set screws onto the toyota valves as a dustcap would. Works great.
