I,ve got an W11 version 2gb + 32gb with original factory firmware (July 21]
I,ve got a couple of issues I cant get rid of.
I cant change time zone. Its stuck on China no matter if I try to change it manually or automatic by location or network. If I set time manually, eventually its changed to China time.
The apps and system is always on night mode. The radio detects night and day and changes brightness correctly, but If i set apps with automatic night mode (maps, Waze, etc) their always on night.
@Manuel g
problems are the same for both issues, the time region... the system is assumed to be in CHina time, so when you are using the unit (assuming Spain time) it is night at China. Please upfgrade your system with the last available ota for your unit W11
https://www.dropbox.com/s/om4kil7nt1lvx6u/HA3_rk3566_11.0_20220214_ota.rar?dl=0
Thanks Iker.
Firmware updated and now I can change time zone. It doesnt change automatically by GPS or WIFI, but anyway, It's set to Spain now I the time is correctly showed.
However, the night mode is still always on. I can chage apps to always display light mode (even at nights!) but if set to auto dark mode is always shown. Dark / Light mode shouldt go by head lights? Brightness reducion at least do work with lights on / off switch. All system apps (config, notificacions layer, amp, etc. are always in dark mode and can't change it)
@Manuel g i dont know how it is resolved by software...Vivid launcher resolves it by specific time...I remember that some specific version on Android 9 changed it accordig to the car light. i dont have the W11....but according to the commercial images, the laucnher and style seems to be the same as the HA for PX6... I dont know if anyone with the HA firmware could help you with this behavior of dark/light theme.
My canbus (or software related to canbus) detected my unit always at night (detected always the lights on....and therefore the screen brightness was always reduced)....so i decided to not check the car light status....there is a setting on "factory settings" - others
Hi, I'm having the same timezone issue on my unit. Can you point me to the correct update?
Android version
11
Android security update July 5, 2021
Google Play system update February 1, 2021
Build number
rk3399-userdebug 11 RQ3A.210705.001 eng.hct.20211228.120947 release-keys
Kernel version
4.19.193 #195 Fri Dec 24 10:38:17 CST 2021
MCU version
MTCH_HA_V3.80_1 Jul 22 2021 09:27:07
Thanks.
@Be Ford for your specific unit (px6 android 11) any of these can be used:
Android 11 Update
MAX11 Version:Make Sure your unit is PX6 Andorid 11
HA3_rk3399_11.0_ota(20220705)
https://www.dropbox.com/s/ibxi1mqtbxy89wh/update.zip?dl=0
telenav_vivid_rk3399_11.0_ota(20220719)
https://vividota.oss-cn-shanghai.aliyuncs.com/tmp/HCT_Telenav/To_Angwei/5.6.3408/telenav_vivid_rk3399_11.0_ota(20220719).zip
I'm having the same issue with my MAX10 unit. Can I upgrade to Android 11 or Vivid software??
@Steve Tobin
If you are on Android 10, stay on 10 (it is more stable). You can always switch between MAX10, VIVID10 ROms when you want
