Hello I am trying to understand why the Dasaita radio device does not work when the starter is in accessory mode with my original radio I did not have this problem and since I installed the Dasaita radio I have to put the starter in ignition contact which damages the battery please help me solve this problem otherwise I am seriously thinking of returning the device
Thanks in advance for your help
@Robert Fleury it works on acc mode as well...check your connections
@Robert Fleury be warned that Dasiata will completely ignore you if you request a refund. Much better to do a chargeback via your credit card company.
@Iker Gomez Please check if your harness has ACC signal, if not, connect the
Cable ACC from unit to car ACC power manually my connector including the wires from 1 to 20 is well connected and it still does not work in acc mode
@Robert Fleury my harness is good and my unit works in both acc and Ignition.
