Please i need help to my PX6 MAX10 sistem..
i normaly use ios.. so i dont now so much about android..
i see that android have a version 12
but my android in my car is 10..
how/where can i download the newest version,
and do i need to do it
@Lokman Yildirim you don't need to update. If works let it as it is
It works as well,, but my google app and google chrome dosent work.. i think that's maybe because of the update
Ajuda, tenho um dasaita px6 max 10 instalado no Toyota CHR 2019, não me aparece o sistema hybrid e todas as notas tais com "AC; portas abertas " , não sei se estou com as configurações corretas ou tenho que atualizar, pois o aparelho era para os carros de 2016 a 2018, comprei usado mas na primeira ligação apresentavo tudo. Obrigado.
@Carlos Fernandes go to Android Settings | Car Settings | Factory settings: Password = 126
the go to the Tab "Canbus" and check which canbus is selected.
@Iker Gómez não existe canbus especifica para o carro, selecionei todas as opções disponiveis para Toyota e não funciona.
@Carlos Fernandes and what canbus box do you have installed? Would you mind to post a picture of your canbus box?
conforme junto envio fotos da canbus a 1 foto diz é a que esta instalada mas tenho a segunda tambem |
@Carlos Fernandes thanks. It is strange ..your canbus must be selected as some Toyota option from "Simple" manufacturer.
Check your cables.are well connected between unit and canbus
Obrigado está tudo ligado e não funciona
@Carlos Fernandes then will be some compatibility issues...did you check previously with Dasaita seller if your hybrid system is compatible? Or did you mention that you have an hybrid CHR? I recommend you to post over Totyota subfoum in order other user could help you
