Hi, I just installed a Dasaita Max11 with "build number" rk3399-userdebug 11 RQ3A.210705.001 eng.hct2.20220704.105700 release-keys.
Should be Android 11 with Max11.
I installed it on a Toyota C-HR 2018.
About mcu: I currently have MTCE_HA_V3.78_4 May 31 2021 20:01:07
On the firmware page there is an update to MTCH 3.80: what should I do?
Is it possible to have a changelog for new mcu version?
Hello, your unit only supports MTCE and the last one released by Dasaita is 3.78
Usually MCU updates are related to new canbus models introduction.....in the case of MTCH, it seems new MCU chip is involved and tha's why MCTE updates are not compatible with MTCH and viceverse.
Hello, a month ago I received a Dasaita Android 11 VIVID11 to which I had the Firmware changed by Dasaita by inserting the MAX11, since I have problems on some side keys including the fact that I can't turn it off, I tried, following the advice that he gave me the assistance of remapping the side Touches trying to align them with the MAX11 but when I get to the remapping I can't find some keys to be able to do it.
This problem could be related to the fact that I have the latest MAX11 firmware but as MCU I have MTCH_HA_V4.01_1?? I can't find this MCU in the released ones.
CCan you hepl me?? Thanks, Mauro
Hola buenas, actualmente tengo una Dasaita px6 con vivid 10, y me gustaría actualizar, ya que no se hizo nunca, pero no se que actualización debo de descargar para mi modelo adjunto imagen.
Gracias y un saludo.
@Pablo Molina Tu versión de MCU si no me equivoco está actualizada así que no necesitas actualizarla. Por tanto, necesitarias actualizar el firmware con la versión que hay para android 10 para vivid (ahora lo ponen vivid+scout), lo encontraras en el apartado de firmware en el foro.
En todo caso, espera a que te conteste el servicio oficial o algún usuario con más experiencia. No vaya a equivocarme al haberseme pasado algo por alto.
Si quieres subir a android 11 con VIVID 11. Te recomendaria que revisaras manuales para hacerlo y los bugs que te puedes encontrar. No es tan trivial cómo la actualización propia de VIVID 10.
Ahora viene lo malo de VIVID en general. El problema es que vivid lo han fusionado con scout (otro launcher con navegador) y vas a tener problemas con el plugin de navegación de la izquierda (te va a desaparecer). Supongo que usas el launcher de vivid con la pantalla partida (izquierda navegador, derecha multimedia).
El nuevo plugin de navegación usa un navegador que no da soporte a europa y por tanto, o sale en blanco o se deshabilita y te sale un cuentakilometros y un reloj en su lugar. esto sucede con la versión del launcher VIVID 7.xxx
Tenlo en cuenta al actualizar.
