[Camry ‘14] Can’t turn on WiFI on Max 10 PX6 (Scout)
  • I did a factory reset on the headUnit, I can turn on WiFi.
    I keep touching the WiFi switch (in settings) to turn it on but it flicks off immediately.
    How do I fix this please.
    Timeline:
    installed unit on friday 12/2/22
    everything worked fine, WiFi, bluetooth
    then Saturday 12/3/22, upgraded the scout OS OTA , also logged in to google and updated apps. Everything still working after that.'few hours later, tried to connect zLink but it would detect iPhone.
    thats when I did a factory reset and now WiFi will NOT turn on no matter how many time I keep pressing the "on" switch button in settings, it just immediately turns back off.
    any help is appreciated please
    see build/firmware info....
  • I upgraded from the firmware files... but the WiFi button will still not turn on...
  • Installed vivid10 and Wi-Fi works now
  • @Eze Egwu Hello
    I have a same issue with my dasaita :( you sais that you installed Vivid10, tell me where did you found this version please ?
    thanks a lot
  • I have the same issue, i have max 10, updated it to vivid 10, now my wireless carplay won't connect, the wifi and wifi hotspot won't turn on. Pls help!!
